هل يجوز تمثيل deep beam على انها shell element اذا كان عمقها 3 مترفىالساب وكيف أحددالوصلة بينها و--
galal zakaria
13 فبراير 2010
هل يجوز تمثيل deep beam على انها shell element اذا كان عمقها 3 متر وكيف احدد الوصله بينها وبين العمود فى الساب
magdyamdb
3 يوليو 2009
dear colleauge, i think that u can model column as a frame element as usual and the deep beam as a shell element not plate element. and then do analysis again comparing the previous results with those coming if u model the deep beam as a shell element and putting thickness of shell element for bending (beam width) equal to zero but keeping membrane thickness as it is , ie., beam width. plz try and feed me back. best regards. dr. magdy
adel rabie
18 يناير 2009
i advise u to divid the column to many beam element at the starting point of connction and also divid the deep beam with the same number of nodes in vertical direction so your deep beam wil divided to manay shell element with the same number of nodes of the beam element
please notice the the most corrected ratio of the element dimension beteween horzontal and vertical dimesion of element is 1 to 2
