نسخة windows 7 cd live feb 2011 على أكثر من سيرفر
alih3s
1 يونيو 2009
نسخة الويندوز انهارت أو سقطت لا مشكلة يمكنك نسخ ملفاتك من البارتشن الذي يحوي الويندوز بكل سهولة مع هذه النسخة الحية التي تساعدك على تشغيل النظام حتى لو انهار لتتاح لك الفرصة لنقل ملفاتك قبل انزال نسخة جديدة
Windows 7PE Live CD (Feb 2011) [Reuploaded] | 675 Mb
شرح لامكانياتها :
Most of the Applications on this 7PE ISO are Portable Applications, they were incorporated into the CD/ISO but you can run any other external Portable app as well.
If after booting up the CD some of your Hardware drivers were not recognized, go to "Administrative Tools --> Hardware" and run the items listed as 1,2 and 3.
Most Portable Apps are up-to-date as Feb 2011
The two Internet Browsers: IE8 and Firefox 3.6.13 are functional and Adobe Flash Player is working.
If you have 2 NICs in your PC and both of them are recognized, one will connect to the Internet and the other one has to be manually configured for your Private LAN. After that, you can connect to other resources on your LAN by using the command:
Net USE * \\Computer\SharedDirectory Password /USER:Computer\Username
Replace "Computer" by the Computer Name, "ShareDirectory" by the name of the directory/drive shared by that computer, "Password" is the one you use
To connect to that resource and "Computer\Username" is the user name you use to connect to that computer. You can create a file with the following
نأتي لروابط التحميل :
filesonic.com
http://www.filesonic.com/file/82328806/7PE1.part1.rar
http://www.filesonic.com/file/82369632/7PE1.part2.rar
enterupload.com
http://www.enterupload.com/oxd4ahjna8xe/7PE1.part1.rar.html
http://www.enterupload.com/wizcas9pavlj/7PE1.part2.rar.html
fileserve.com
http://www.fileserve.com/file/s6qPWAN
http://www.fileserve.com/file/b2Qpbya
usershare.net
http://www.usershare.net/0jrha20rsnp8
http://www.usershare.net/cnwo1dm2rhfj
