نداء عاجل لجميع المهندسين !!
ABDOH10
23 فبراير 2012
ما اطول عليكم انا طالب ادرس هندسة مدنية في جامعة في برطانيا
المهم في سؤال من دكتور في قسمنا في مادة مشتركة بين الهندسة المعمارية والمدنية عقدني جدا وحاولت فيه جدا
وما بقي عندي وقت ولازم اقدم الحل قبل الويك اند......:4::4:
قلت مالك الا اخوانك في المهندسين العرب واكيد راح تساعدوني لان مالي غيركم
والسؤال هو اللي بنزله الحين وطبعا بالمرفقات الرسمه ما قدرت انزلها هنا.....واللي ما يقدر يساعدني يدعيلي دعوه ربي يوفقكم جميع وبنتظار ردكم
Building Services Engineering
BSV09114
Year 2011/2012
[FONT=Arial,Arial][FONT=Arial,Arial]The plan and section through an office in a multi-storey office building are given. The orientation of the building is such that the external wall of the office faces due south.
The latitude of the building is 51.7°N.
Rooms adjacent to, above and below the office can be assumed to be at the same environmental temperature as the office.
The activities carried out by the workers are typical of office work in terms of Met value. The office has a typical Relative Humidity of 50% and the clothing of the workers is typically light summer clothing during the summer months.
The ventilation system provides a typical Relative Air Velocity over the workers of 0.2 m/s and an overall ventilation rate of 2.0 air changes per hour in the office.
You are asked by the building owners to produce a report (With all calculations in an appendix) of the predicted mean and peak internal environmental temperatures in August (based on 22
[/FONT]
[/FONT][FONT=Arial,Arial][FONT=Arial,Arial]nd[/FONT][/FONT][FONT=Arial,Arial][FONT=Arial,Arial]) and to compare the temperatures with the optimum comfort temperature.
Your report should include
[/FONT]
[/FONT]one [FONT=Arial,Arial][FONT=Arial,Arial]practical method of reducing peak temperatures from solar heat gain [/FONT][/FONT]including [FONT=Arial,Arial][FONT=Arial,Arial]supporting calculations showing the effectiveness of the method.
[/FONT]
[/FONT][FONT=Arial,Arial][FONT=Arial,Arial]The specifications of the elements are as follows: External walls [/FONT][/FONT]
 Brick outer leaf
[FONT=Arial,Arial][FONT=Arial,Arial]L/W concrete block inner leaf
[/FONT]
[/FONT] Dense plaster on inside face
 13mm polystyrene insulation in cavity
 Dark external surface
 U-value =0.7 W/m2°K.
[FONT=Arial,Arial][FONT=Arial,Arial]Windows [/FONT][/FONT]
 Single glazing with clear glass and no shading
 U-value = 5.7 W/m2oK
[FONT=Arial,Arial][FONT=Arial,Arial]Internal walls [/FONT][/FONT]
[FONT=Arial,Arial][FONT=Arial,Arial]L/W concrete block plastered both sides
[/FONT]
[/FONT][FONT=Arial,Arial][FONT=Arial,Arial]Floor [/FONT][/FONT]
 concrete slab with screed and carpet
[FONT=Arial,Arial][FONT=Arial,Arial]Ceiling [/FONT][/FONT]
 underside of concrete slab with screed and carpet
الملف مرفق
  • BSV09114_TR2_11-12_CW1.pdf
    75.7 KB · المشاهدات: 36
ABDOH10
23 فبراير 2012
يالله ياكريم 64 مشاهده ولا رد!!!!!!
up up
