مطلوب الحلول لكتاب POWER PLANT ENGINEERING المؤلف A.K .Raja
فــاهم
27 يناير 2008
مطلوب الحلول لهذا الكتاب POWER PLANT ENGINEERING BY A.K .Raja
images
فــاهم
27 يناير 2008
معقولة ما فيه احد عنده ؟؟
فــاهم
27 يناير 2008
يا أخوان معقولة ماله حلول ؟؟؟؟؟؟؟؟
المصري 00
11 مارس 2007
يا بش مهندس فاهم من فضلك أكتب الأسئلة وأحنا نجاوب ولا المفروض اننا نجاوب علي أسئلة مش موجودة
كدة ولا ايــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــــه
فــاهم
27 يناير 2008
السؤال الأاول
A sample of coal has the following molal analysis C 67.35%, H2 26.26%, O2 2.28%, N2 0.57%, S 1.37%, H2O 2.17%. Write the complete combustion equation in stoichiometric air and calculate the coal ultimate analysis, mass percent.
السؤال الثاني
6. Hydrogen burns in pure oxygen in a chemically correct (stoichiometric) mixture. Write the combustion equation and calculate (a) the mass of products per unit mass of H2, and (b) the lower heating value of H2 if its higher heating value is 61,100 Btu/lbm.
السؤال الثالث
7. A gaseous fuel that is derived from coal has the following ultimate volumetric analysis: H2 47.9%, methane (CH4) 33.9%, ethylene (C2H4) 5.2%, CO 6.1%, CO2 2.6%, N2 3.7%, and O2 0.6% It burns in 110 percent of theoretical air. Calculate (a) the volume flow rate of air required per unit volume flow rate of the gas when both are measured at the same pressure and temperature, and (b) the dew point of the combustion products, in degrees Fahrenheit, if the total pressure is 2 atm.
السؤال الرابع
8. A southern California natural gas has the following ultimate analysis by mass: H2 23.3%. CH4 72% N2 0.76%, and O2 1.22%. The flue gases have the following volumetric analysis: H2O 15.583% SSWc. CO2 8.387%, O2 3.225%, N2 72.805%. Calculate (a) the percent
المصري 00
11 مارس 2007
إن شاء الله سوف أرد عليك قريبا
ebeed2
20 أبريل 2011
ممكن الكتاب نفسة
