طلب ماهو ال sequential construction analysis ارجو الافادة وشكرا
Mahmoud.14
8 يوليو 2015
السلام عليكم ورحمة الله
Mahmoud.14
8 يوليو 2015
اشكرك يا مهندس جمال وجزاك الله خيرا
امين الزريقي
22 سبتمبر 2008
Staged construction is a static modeling, analysis, and design application which enables the definition of a sequence of construction stages in which structural systems and load patterns are added or removed, and time-dependent behaviors are evaluated, including creep, shrinkage, aging (change in elastic modulus with age), and tendon relaxation. Material and geometric nonlinearity may be applied to staged construction. Further, staged construction may be part of a sequence of nonlinear static or direct-integration time-history analysis load cases. For linear load cases, the structural stiffness at a given construction stage may serve as the basis for analysis.
Staged construction is available in select program levels. Please refer to the Compare Levels page for the product you are working with. Additional details, including specifics on input parameters, are described in the CSI Analysis Reference Manual (Staged Construction, page
396).
  • Technical-Note-No.-TN-S03 Sequential Construction Analysis.pdf
    2 MB · المشاهدات: 12
  • Effects of P-Delta and Construction Sequential analysis of RCC and Steel Buildings with respe...pdf
    1.2 MB · المشاهدات: 13
  • Importance of Construction Sequence Analysis in design of High Rise Building.pdf
    483.2 KB · المشاهدات: 9
  • Simplified sequential construction analysis iran .pdf
    818.8 KB · المشاهدات: 10
