كيفية اعداد عدة صفحات في ملفات اوتوكاد
hamzasirri
30 أبريل 2011
ISSUE:
After getting a new printer or changing the default printer that you use when plotting from AutoCAD, you would like to know how to change the page setups in all your drawings so that they use the new printer.
SOLUTION:
Open one of autocad drawing and setup the page then save and close as shown in the below video.
  1. Open new drawing and type DWGCONVERT at the command line .
  2. Choose the conversion setup you want, then click "conversion setups"..
  3. Click modify.
  4. Check replace page setups", then click the "page setup" button
  5. Click "browse" and select the drawing or template that has the desired page setup(s)
  6. Select the page setup(s) to import.
  7. Click OK and close.
  8. In the DWG Convert window, add the drawings you wish to replace the page setups in and then click Convert.
Consider that this will works with named page setups. If you modified default page setup, they will not be replaced.
You can also print multiple drawings without open cad files
setup multiple pages in autocad
setup multiple pages in autocad -1
setup multiple pages in autocad - 2
setup multiple pages in autocad - 3
setup multiple pages in autocad - 4
setup multiple pages in autocad - 5
OK and close
setup multiple pages in autocad - 6
add the drawings to setup multiple pages
ISSUE:
SOLUTION:
  3. Click modify.
OK and close
[URL="http://www.autocadproblems.com/2016/10/how-to-setup-multiple-pages-in-autocad.html"]setup multiple pages in autocad[/URL]
