كورس رائع جدا في تصميم الخرسانة المسلحة
gadora516
26 أكتوبر 2009
محتوي الكورس
01- Introduction of R.C. Design..pdf
02- Architectural & Structural Drawing..pdf
03- Units & Dimensions..pdf
04- (Beams) (1) Max-Max B.M.D & S.F.D. For Beams..pdf
04- (Beams) (2) Loads on Beams (Load Distribution)..pdf
04- (Beams) (3) Design of Beams using charts..pdf
04- (Beams) (4) Design of Beams using First Principels..pdf
04- (Beams) (5) Design of Beams due to Shear & Torsion..pdf
04- (Beams) (5) Reinforced of Beams using Imperical method..pdf
04- (Beams) (6) Reinforced of Beams using Moment of Resistance method..pdf
05- (Columns) (1) Design of sections of Columns..pdf
05- (Columns) (2) Short and Long Columns..pdf
06- Reinforcement of Frames..pdf
07- (Slabs) (1) Solid Slabs..pdf
07- (Slabs) (2) Hollow Blocks Slabs..pdf
07- (Slabs) (3) Flat Slabs..pdf
08- Stairs..pdf
07- (Slabs) (4) Panelled Beams..pdf
09- (Systems) (2) Girders & Frames.pdf
09- (Systems) (3) Polygon & Arched Frames.pdf
09- (Systems) (4) Parabolic Slabs.pdf
09- (Systems) (5) Joints.pdf
09- (Systems) (6) Real Supports.pdf
09- (Systems) (7) Radial Frame.pdf
09- (Systems) ( Truss & Vierendeel.pdf
09- (Systems) (9) Wind Effect & End Gables.pdf
للتحميل
http://kvolcano.ahlamontada.com/t183-topic
منقول
s.sakr
14 أغسطس 2010
جزاكم الله عنا كل خير وبارك الله فيكم
AAB249
23 أبريل 2010
بارك الله فيك وشكرا جزيلا على الموضوع
eldabaawy
6 ديسمبر 2009
بارك الله فيك وفى صاحب الموضوع الاصلى وشكرا
egyptsystem
6 ديسمبر 2013
