كتاب CSWE Certified Solidworks Expert Perparation Materials
أحمد دعبس
15 فبراير 2008
أخوانى فى الله
أحضرت لكم كتاب
كتاب التدريب على إمتحان الخبير في السوليدوركس (إكسبيرت)
Paul Tran
ويتناول الموضوعات الأتية :
Introduction: Are you the next CSWE?
Surface Modifications 1-1
Chapter summary I- l
Tools needed 1-2
Opening a part document 1-3
Working with Surfaces 1-3
Deleting the faces 1-3
Measuring the angle 1-4
Rotating the handle 1-5
Recreating the surfaces 1-6
Hiding a solid body 1-8
Trimming the surfaces 1-9
Showing a surface body 1-10
Knitting all surface bodies 1-10
Creating a section view 1-11
Measuring the mass 1-11
Exercise: Surface Modifications 1-13
Assembly Modifications 2-1
Chapter summary 2-1
Tools needed 2-2
Opening an assembly document 2-3
Editing the first component 2-3
Adding Draft 2-4
Viewing the draft results 2-5
Editing the second component 2-6
Replacing a plane 2-6
Repairing the sketch errors 2-7
Correcting the end condition 2-8
Exiting the edit component mode 2-9
VITable of Contents
Chapter 3:
Measuring the center of mass 2-10
Exercise: Using manual drafts 2-11
The Order of Fillets
Chapter summary
Tools needed
Comparing the fillet results
Planning the order of fillets
Adding the face fillet
Creating the constant fillet
Adding another constant fillet
Measuring the mass
Exercise: Fillet Options
Chapter 4: Flat Spring Assembly 4-1
Chapter summary 4-1
Tools needed 4-2
Starting a new part template 4-3
Creating the helix - the sweep path 4-3
Creating the sweep profile 4-4
Adding the pierce relation 4-5
Creating the swept feature 4-5
Creating an axis 4-6
Opening an assembly document 4-7
Inserting the part into an assembly 4-7
Showing the axis 4-7
Adding mates 4-8
Checking the degrees of freedom 4-8
Adding coincident mates 4-9
Applying dimension changes 4-11
Viewing the results 4-12
Calculating the center of mass 4-12
Exercise: Spring Assembly 4-13
Chapter 5: Part Modifications 5-1
Chapter summary 5-1
Tools needed 5-2
Opening a part document 5-3
VIITable of Contents
Chapter 6:
Modifying the model
Converting the outline of a feature
Deleting the on-edge relations
Removing the raised feature
Creating a cut
Recreating the sweep path
Using projected curve
Creating a swept feature
Calculating the mass
Exercise: Part modifications
Replacing External References
Chapter summary
Tools needed
Examining the existing mates
Suppressing the inplace mate
Adding a concentric mate
Editing a component
Replacing the sketch plane
Viewing the external ref. symbols
Adding new mates
Adding a distance mate
Exercise: Replacing External References
Chapter 7: Working with Multibody Parts
Chapter summary
Tools needed
Switching to the part level
Editing a feature
Using Move / Copy / Constraint
Adding mates
Changing the display option
Using the combine command
Using combine add 7-7
vSwitching back to assembly 7-8
Rebuilding the assembly 7-9
Measuring the center of mass 7-9
Exercise: Combining Multibodies 7-11
Creating a Curved Spring 8-1
Chapter summary 8-1
Tools needed 8-2
Starting a new part template 8-3
Creating the sweep path 8-3
Creating the sweep profile 8-4
Creating a swept feature 8-4
Setting the twist type 8-5
Entering the number of turns 8-5
Assigning the material 8-5
Calculating the final mass 8-6
Exercise: Circular Spring - Expanded 8-7
Working with Sketch Pictures 9-1
Chapter summary 9-1
Tools needed 9-2
Creating a layout sketch 9-3
Inserting the picture 9-4
Locating the picture 9-4
Scaling the picture 9-5
Tracing the picture 9-5
Creating the offset entities 9-7
Closing the traced sketch 9-7
Adding the sketch fillets 9-8
Adding the revolved centerline 9-9
Revolving the sketch profile 9-10
Measuring the mass of the part 9-10
Exercise: Sketch picture - Eagle head 9-11
Using Cut with Surface 10-1
Chapter summary 10-1
Tools needed 10-2
Opening an assembly document 10-3
Editing a component 10-3
IXTable of Contents
Chapter 11:
Creating a surface offset 10-4
Creating a surface cut 10-5
Flipping the cut direction 10-5
Hiding a component 10-6
Hiding a surface 10-6
Adding fillets 10-6
Exiting the edit component mode 10-8
Calculating the mass 10-8
Exercise: Cut with Surface 10-9
Using Belt Chain 11-1
Chapter summary 11-1
Tools needed 11-2
Staring a new part template 11-3
Creating the main sketch 11-3
Making the blocks 11-4
Creating a belt chain 11-5
Entering the belt length 11-6
Adding the driving angular dimension 11-7
Adding a reference dimension 11-7
Applying dimension changes 11-8
Checking the new belt length 11-9
Changing the pulley's angle 11-9
Entering the new belt length 11-10
Exercise: Creating a belt chain 11-11
Glossary
Index
SolidWorks Quick-Guides:
Quick Reference Guide to SolidWorks Command Icons
and Toolbars.
أتمنى أن تستفيدوا منه وأن ينال إعجابكم
رابط تنزيل كتاب CSWE Certified Solidworks Expert Perparation Materials
