قطع الاغانى والاناشيد وحولها لنغمات فى ثوانى وضعها على موبايلك مع العملاق المجانى Mp3 Cutter
احمد الصرافى
4 يناير 2010
برنامج Mp3 Cutter 1.2.0 الشهير والمجانى هو من افضل البرامج التى تعمل على تقطيع الاغانى وال mp3 فى لحظات بكل سهولة ويسر كما مضاف للبرنامج شرح كامل لطريقة التسطيب وضبط الاعدادات والتشغيل كما انه برنامج مجانى مما يضمن لك استمرارية عمله .
Mp3 Cutter 1.2.0
Easy MP3 Cutter allows you to split a large MP3 or WAV file into a number of smaller ones. This can be useful in separating logical parts of a continuous recording and organizing them for easy access, or in case you need only a part of the recording (for example, to use later as a tune for your cellular phone). The program is small and handy, it doesn’t require its user to be experienced in audio editing. You can automatically cut your MP3 or WAV file into equal parts by specifying duration, number of output parts or size of each resulting file. If there is silence between the parts you want to extract, the program can detect it and mark the parts for splitting with just one click. In addition, visual splitting option is available, in which the splitting boundaries are set manually on the audio waveform. Built-in audio player helps to recognize and to verify the exact point of splitting. Easy MP3 Cutter doesn\'t recompress your files, so no quality losses occur during splitting.
Moreover, no recompression means better performance. The program supports Drag&Drop, batch processing (splitting multiple files in a row), multilingual interface, and can supply output files with user defined ID3v1 and ID3v2 tags. It saves your time by doing complex tasks simple. download your copy of soft2morrow
شرح البرنامج
متواقف مع
All windows
حجم البرنامج
5.95 kb
حمل من هنا
safety113
6 ديسمبر 2008
بارك الله بك
الف شكر
