طريقة معالجة التشققات في الخرسانة بواسطة الحقن بمادة الايبوكسي
3 مارس 2008
اليكم طريقة معالجة التشققات في الخرسانة بواسطة الحقن بمادة الايبوكسي[h=2]High pressure injection packer for concrete crack repair[/h]
injection packer for concrete crack repair with 7 different size.We also accept customized size to manufacture
[h=2]
[/h]
1, Made from aluminum
2. hard injection packer
3. inject for epoxy
4. Inject for PU​
High pressure injection packer for concrete crack repairing is a kind of high pressure grouting machine accessoriesthe.It use the principle of loop pressure fastening. The head of packer is supplied with a single-way valve,which can prevent the slurry at high pressure into the pour spout.​
Injection packer for concrete crack repair is a kind of high pressure grouting machine accessories is usually to applicate in the following situation:
1. Roof concrete slab cracks, wall pipe, wall, water leakage, water blocking.
2. Subway, tunnels, culverts, sewage treatment pond, the water leakage cracks in concrete, with water blocking.
3.Concrete structure, beam, column, slab cracks, high pressure injecting epoxy resin.​
4.Basements, underground garage, underground passage, the water leakage cracks in concrete, with water blocking.​
Features
High pressure injection packer for concrete crack repair is the accessory to be , waterproof ,rehabilitation of concrete structures , basement leak sealing cracksealing etc.
You can use injection machine in concrete crack repair and water leaking stop. It suits for both polyurethane and epoxy injection.​
[h=2]How to repair concrete crack with Injection packer for concrete crack repair?[/h]
1.Crack and leakage condition inspection
Check the process procedure after finding the thickness, width and depth of crack and leakage condition of the structure​
2.Drilling Operation
Drill directly into crack section if the thickness of concrete is thinner than 10cm. For the thickness of 10~50cm, drill it with 45 degree angle by keeping a distance of 1/5 of concrete thickness. Make sure it penetrates the crack section. If the thickness is over than 50cm, keep the distance of 20~30cm and drill it with 45 degree angle until it penetrates crack section. And keep drilling by maintaining the fixed interval. (5 holes per 1 meter. Drill it in zigzags)​
3.Cleaning the crack
4.Injection packers installation
After clean the inside of drilled holes with compressor,then make sure that rubber sleeve of packer and cutting line of tightening nut should be put into the inside of concrete surface when installing. Tighten the packer completely by using the T-box. (Packer might be damaged if you tighten it too strongly)​
5.Surface seal crack
5.Injection Operation,Polyurethane high-pressure injection
Inject the waterstopping material by using the high pressure device or grease gun. Maintain the initial injection pressure as around 40kg/cm and increase the pressure by each 10kg/cm gradually until the waterstopping material flows out from crack section. Water will come out from the crack section first and then waterstopping foaming agent and then water stopping liquid at last. If the waterstopping material that is not foamed comes from the crack section, then move to next packer for injection.​
6.Packer Removing Operation
Remove and break the packer by using vise pliers or hammer as a tool. If there is still a wet section, then inject the water stopping material again.​
7.Finishing Operation
Remove the water stopping material that is remained on the crack section. Spreading with the elastic sealing material.​
*Note:We can produce at any sizes Injection packer for concrete crack repair according to your requirements.​
Related Keywords: Injection packer for concrete crack repair,Aluminum Grouting Injection Packer,Injection Packer , Epoxy Injection Packer , Plastic Surface Packer , Resin Injection Packer,Injection packer for concrete crack repair​
Eng.El Seidy
1 يناير 2014
جزاكم الله عنا خير الجزاء ونفع الله بنا وبك أستاذنا الفاضل
