ساعدوني يا جماعه في هالسؤال
drasticxx
4 فبراير 2009
hi all
i am structural engineer, and i tok an enviroment course because the course options was limted
i have a question to solve but thr problem i feel stupied because my back ground in this area is zero
so please help me
and im sorry to write in english since the keyboard only habe emglish letters
the question is
A soil has a porosity of 0.23, a bulk density of 1.87 Mg/m3 and a permeability of 9.6 x10-8
m/s. It is being used as a clean-up barrier 450mm thick underneath a waste deposit that covers 50 x 120 m plan area. There is a hydraulic head of 1.8m across the barrier. If the contaminant concentration in the fluid which passes through the barrier is, initially, 125 mg/l, calculate how much contaminant escapes through the barrier in 30days. The partition coefficient is 25 l/kg. Ignore diffusion and dispersion effects in this case and assume that the thickness of the barrier acts uniformly.
Hints:
1) you will (probably1) need to calculate the ratio of the mass of solids to the volume of water in the soil.
2) you may consider the flow through the barrier as being a number of discrete transits, each comprising one bed-volume which suddenly replaces the previous bed-volume, waits without moving for the length of time indicated by the transit time, and then is suddenly displaced by the next bed volume.
3) I suggest you work out the contaminant that escapes for the first bed-volume; then work out the volume escaping in the second bed-volume. After that you will be able to set up a spreadsheet-based solution for as many bed-volumes as you need.
please help me ,because i feel lost
drasticxx
4 فبراير 2009
شباب عندي تسليم خلال اسبوع وانا ضايع
رجاء تساعدوني ما الي الا الله اولا ثم انتم
شكرا لكم جزيلا
انا عارف انه مش الكل يعرف في هالموضوع وهاي مشكلتي لانه مش تخصصي
من شان هيك ضايع
مصعب الممصعب
5 يونيو 2008
ترجم لنفهم . يعني تكتب تعليق وعنوان عربي بس السؤال لا؟؟
drasticxx
4 فبراير 2009
اخي الكريم او التعليق بالعربي لاني بالبيت واستعمل جهازي الخاص مش جهاز الجامعه
بس ما فهمت شو قصدك ترجع للفهم
شكرا
