سؤال : بخصوص تحديث برنامج pm fastrack 8
doha_4all
14 مارس 2009
قمت بعمل تنصيب للبرنامج و تم بنجاح و الحمد لله و لكن هناك مشكله و هى ان الاسئله الموجوده فى قاعدة البيانات
قديمه جدا و عند عمل تحديث لقاعدة البيانات تظهر رساله تفيد بانه هناك خطأ فى قاعدة البيانات و يتوقف البرنامج عن العمل
قمت بالبحث على المواقع المختلفه و وجدت طريقه فى احد المواقع الاجنبيه و هى كالاتى :
Installation Instructions:
1. Download the zip file from the location mentioned in the first page of this thread.
2. Extract the package using any zip software, preferably Winrar.
3. Open the extracted folder and locate the file named "PM_FASTrack_PMP_v8_setup".
4. Disconnect your computer from the internet and install the above software.
5.Click 'Activate' and click 'Accept' afterwards.
6. In the License Serial box, type in the word MANUAL and press 'Next' (Make sure this is without quote and in upper case).
7. Run the file named "ckInfo+", which is located in the 'Crack' folder.
8. Select the file 'fast.ckInfo', which is also located in the Crack folder.
9. Now type the "Site Code" from the PMP Fast Track window, into the command prompt window and press Enter.
10. You will be presented with some text.
11. Now, type in the "Encrypting Key" from the command prompt, into the "PMP Fast Track" window, in the field named "Site Key".
12. Click next and wait for the program to process.
13. Your software is now activated.
14. Close your software
15. Make a backup of the folder "PM FASTrack PMP v8" from under "C:program Files" (idea is to backup files like app_config.xml, indexes.xml, RMCPROJ.ckn, slog.txt)
16. Open your software and connect to the internet and let the database update.
17. After successful database update, when you see message "Applying update..." disconnect the internet
18. Don't open anything from application menu, just close the application
19. Now compare the backup of folder you made in step 15 to the folder "PM FASTrack PMP v8" (after database update) under "C:program Files"
20. Try restore all files (app_config.xml, indexes.xml, RMCPROJ.ckn, slog.txt) except "database.xml"
21. Now you have successfully activated the application and updated the database (don't care about the database update shown in the application "About")
22. Use the application (try exams) with internet connection disconnected (otherwise application will try to update database automatically and corrupt the database again)
نفذتها كما هو مكتوب بالحرف و للاسف نفس النتيجه
بالله من لديه طريقه لعمل تحديث بطريقه صحيحه للنسخ المكركه
يفيدنا به ... اعتمادى على الله ثم على مهندسي الملقتى
تحياتـــــــــــــــــــــى
doha_4all
14 مارس 2009
ياريت لو اى حد عنده معلومه يفيدنى بيها
doha_4all
14 مارس 2009
220 مشاهده ولا توجد ولا مشاركه
doha_4all
14 مارس 2009
مازل املى ف الله كبير ثم فى مهندسي الملتقى لافادتنا بحل للمشكله
الأسد الجريح
22 مايو 2007
الإصدار 8 المكرك الموجود حالياً يتم ضربه من قبل الشركة rmc إذا قمت بتحديثة
الحل أن تنتظر حتي يتم ضرب الاصدار الجديد أو تعمل علي الاصدار الموجود حالياً بدون تحديث
نايف الشمري
19 أبريل 2007
صارت لي المشكلة فحذفت البرنامج من الجهاز وأعدت تحميله بدون التحديث الذي يوقف عمل الكراك
hanyhoney
20 فبراير 2009
الموضوع سهل نزل البرنامج من 4 shared. الفكرة كلها اكتب كلمة MANUAL مكان SITE NUMBER ثم استكمال التسطيب عادي
hanyhoney
20 فبراير 2009
هو ما هو اهمية التحديث
الزعيم2000
عضو تحرير المجلة
22 مايو 2006
الأخ الكريم
على ما أعتقد أنه هناك فوق ال 1700 سؤال في هذا البرنامج بدون تحديث لقاعدة البيانات
إذا كنت قد وفقت في إجابتهم و دراستهم و تعلم المبادئ منهم فهذا فضل من الله و عليك أن تشترى النسخه الاصليه إذا رغبت في المزيد من الاسئله و تنقيح الإجابات اذا كان متاحا
و إذا كنت في الطريق لدراسة ال 1700 سؤال و لم تنتهى منهم فلا تضيع وقتك في التحديث
ملحوظه / عند قرائتك لحلول الاسئله فمن المفيد ان تقرأ إجابات جميع الاسئله حتى إن كانت إجابتك صحيحه
لان ذلك يساهم بشكل كبير في ترسيخ المفاهيم و إعادة الاستذكار.
بالتوفيق إن شاء الله
