حصريا برنامج الحماية العملاق من مايكروسوفت Microsoft Security Essentials 4.2.223.0 Fi
medo2013
16 يناير 2013
أقدم لكم Microsoft Security essentials v4.2.223.0 Final
= - = - = - = - = - = - = - = - = - = - = - = - = INFO = - = - = - = - = - = - = - = - = - = - = - = - =
برنامج الحماية العملاق من مايكروسوفت microsoft Security essentials 4.2.223.0 Final البرنامج ذاع صيته فى الاونة الأخيرة كأحدأفضل برامج الحماية من الفيروسات على الساحة برنامج متكامل يحميك من كافة الأخطار كالفيروسات و التروجانات بأنواعها و كذلك يحميك من الرسائل البريدية المفخخة الذى يميز هذا البررنامج عن غيره كونه خيفيا جدا على النظام عكس برامج الحماية الأخرى التى يسبب معظمها بطئا ملحوظا فى النظام بالإضافة إلى كونه مجانيا لا يحتاج الى تفعيل
برنامج متكامل بمعنى الكلمة و ينصح به دائما ...
Microsoft Security essentials (MSE) offers award-winning protection against the Internet intruders including viruses, trojans, worms and spyware. MSE is built for individuals and small businesses, but it’s based on the same technology that microsoft uses to protect giant businesses (security products like microsoft Forefront, the Malicious Software Removal Tool, and Windows Defender). microsoft has a whole team watching for new threats and coming up with ways to squash them. microsoft Security essentials is efficient and compact. Scans and updates are scheduled to run when the PC is idle and the software works in a way that your PC is still snappy when you’re using it. All this makes microsoft Security essentials friendly for all sorts of computers – your old PC, your new PC, your laptop, as well as your little netbook. Microsoft Security Essentials uses green, yellow and red color codes to designate the Security status of your PC and a color-coded icon in the taskbar tells you at a glance if your attention is needed. It’s simple – when you’re green, you’re good. However, if there’s a red or yellow threat, MSE will alert you and recommend what to do (you can act directly from the notification area without having to enter the application). Downloading and installing microsoft Security essentials is free (Your PC must run genuine Windows to install microsoft Security Essentials) and easy. Once you have installed it, the software updates automatically once a day. We’re constantly tracking new threats and we keep your PC updated to help protect you. You don’t have to do anything. Microsoft Security essentials has received great recognition for the protection: the VB100 award from Virus Bulletin Ltd., Checkmark Certification from West Coast Labs, and certification from the ICSA Labs. • Real-time protection Real-time protection means addressing potential threats before they become problems. Alerts notify you when spyware, viruses, or other malicious software attempt to run or install on your PC, and suspicious files and programs are prevented from opening. • System scanning Microsoft Security essentials offers complete system scanning capabilities with both scheduled and on-demand scanning options to provide an extra level of confidence. Scheduled scans are turned on by default and configured to run weekly at 2 a.m. when the system is likely idle. There are three scanning options: * Quick scan. On by default, a quick scan rapidly checks the areas malware is most likely to infect, including programs running in memory, system files, and the registry. * Full scan. A full scan checks all files on the PC, the registry, and all currently running programs. * Custom scan. A custom scan allows you to scan only the areas you select. You can choose when you want a scheduled scan to run, view the scan results before cleaning, or run a scan on demand. If the PC isn’t turned on when the scan is scheduled to run, microsoft Security essentials will start the scan at the first opportunity once the PC is awake and idle. • System cleaning When microsoft Security essentials determines a possible threat on your PC, alerts notify you of the threat. Threats are categorized as Severe, High, Medium, or Low, and you can choose whether to ignore, quarantine or remove the item from the system. * Quarantine. microsoft Security essentials blocks less severe threats and moves them to a quarantined queue where you can elect to restore or permanently delete them. By placing an item in quarantine, you can test the effect of the item’s removal before deleting it from the system. * Remove. This action permanently deletes the item from the system. * Allow. This action stops microsoft Security essentials from detecting the item in future scans by adding it to the Allowed Items list. You can remove items from the Allowed Items list at any time. • Windows Firewall integration Having an active firewall is part of securing your PC. During setup, microsoft Security essentials scans the PC to determine if a firewall is active on the PC. If no firewall protection is present, you’ll be given the option to turn on Windows Firewall. • Dynamic signature service Protection needs to be up-to-date to be effective. Dynamic signature is a way to check whether a suspicious program is bad or not. Before a suspicious program runs, microsoft Security essentials pretends to run it to determine what it’s going to do. This gives programs special signatures that are checked against our database of good and bad programs. Programs are watched even after they are approved to make sure they don’t do anything potentially harmful like make unexpected network connections, modify core parts of the operating system, or download malicious *******. • Rootkit protection Rootkits are particularly difficult types of malware to protect against, and microsoft Security essentials includes a number of new and improved technologies to address rootkits and other aggressive threats. * The kernal is at the heart of your PC’s operating system. microsoft Security essentials monitors it to see if there are any attacks or harmful modifications. * Rootkits use stealthy methods to hide themselves and microsoft Security essentials has the latest anti-stealth technology to uncover them. For example, direct file system parsing helps find and remove malicious programs and drivers that rootkits try to sneak in. • Protection against real threats, not good software Microsoft Security essentials helps block bad software. We keep a list of the most popular websites and downloads on the Internet and use it to test our antimalware definitions and updates before they get to you. This helps us make sure that the protection we offer really keeps your PC safe, and not blocked. MSE is available as standalone 32-bit and 64-bit downloads for Windows XP, Windows Vista, and Windows 7.
نسخة x64 نسخة x86 لتحميل البرنامج رابط مباشر ويدعم الاستكمال نسخة x86
