تعلم اساسيات التكييف مع هذه الإسطوانه الرائعه basic refrigeration and charging procedures
eng_abbas_2010
6 أبريل 2009
BASIC REFRIGERATION AND CHARGING PROCEDURES
*NO installation Required. Runs Automatically | 34 MB
A solid foundation in air conditioning and refrigeration principles is crucial to the proper installation, and service of modern systems. Your continued growth and advancement in the industry depends on mastery of these fundamentals.
This course will provide attendees with the knowledge to accurately perform system installation, basic repair, and the information necessary to properly charge modern equipment.
Course Content
Application of Pressures, States, and Conditions
  • Compressor Discharge
  • Condenser Inlet
  • 100% Saturated Vapor Point
  • 100% Saturated Liquid Point
  • Condenser Outlet
  • TXV Inlet
  • Middle of Evaporator
  • Saturated Vapor Point
  • Evaporator Outlet
  • Compressor Inlet
Pressure Drop
  • Friction Pressure Losses
  • Static Pressure Losses
Capillary Tubes
  • Sizing
  • High Heat Loads
  • Low Heat Loads
  • Service
Automatic Expansion Valves (AEV)
  • Charging Procedures
Thermostatic Expansion Valve (TEV)
  • Remote Bulb Pressure
  • Evaporator Pressure and Spring Pressure
  • Additional Pressure
  • Color Codes
  • Special Application TXVs
    • Externally Equalized Valves
    • Maximum Operating Pressure
    • Balanced Port TXVs
  • Selection Procedures
Charging TEV/Receiver/Sightglass Refrigeration Systems
  • Charging Rules
Charging Capillary Tube or Fixed Orifice Refrigeration Systems
  • Charging from a Vacuum (weigh-in)
Charging Capillary Tube or Fixed Orifice Air Conditioning Systems
  • Measuring Duct Velocity
  • Superheat Charging Curves
  • Superheat Curve Theory
  • Charging Capillary Tube-Cooling Mode Only
  • Superheat Method — Capillary Tube System
Download
اضغط هنا للتحميل أو اضغط هنا
eng_abbas_2010
6 أبريل 2009
جزاك الله خيرا
نورتنى واتمنى الإستفاده والمناقشه فى الإسطوانه ومحتوياتها
ربما تحتاج لبرنامج Shockwave player لتشغيل الفلاش تستطيع تشغيله من هنا Adobe - Adobe Shockwave Player
اذا لم تعمل معك
انقل فولدر محتويات الإسطوانه( Basic Ref & Char (D)) بعد فك الضغط الى بارتشن اخر ولا تضعه داخل فولدرات اخرى بحيث يكون فى الملف الجذر للباتشن
ارجوا الرد بعد تشغيلها (تم تجربة التشغيل مرات عديده وتعمل بشكل صحيح) اتمنى لك التوفيق
