بناء دائره انا شخصيا قمت بشراء هذه الدائره لبنائها
imran imran
6 يوليو 2007
CK200 - 3V FM TRANSMITTER
This FM transmitter (FM Tx) is about the simplest and
most basic FM Tx it is possible to build and have a useful
transmitting range. It is surprisingly powerful despite its
small component count and 3V operating voltage. It will
easily penetrate over three floors of an apartment building
and go over 300 meters in the open air.
The circuit we use is based on a proven Australian design.
It may be tuned anywhere in the FM band. Or it may be
tuned outside the commercial M band for greater privacy.
(Of course this means you must modify your FM radio to
be able to receive the transmission or have a broad-band
FM receiver.)
The output power of this FM Tx is below the legal limits
of many countries (eg, USA and Australia). However,
some countries may ban ALL wireless transmissions
without a licence. It is the responsibility of the purchaser
to check the legal requirements for the operation of this kit
and to obey them.
The kit is constructed on a single-sided printed circuit
board (PCB). Protel Autotrax was used to design the
board.
ASSEMBLY INSTRUCTION
Components may be added to the PCB in any order. Note
that the electret microphone should be inserted with the
pin connected to the metal case connected to the negative
rail (that is, to the ground or zero voltage side of the
circuit). The coil should be about 3mm in diameter and 5
turns. The wire is tinned copper wire, 0.61 mm in diameter.
After the coil in soldered into place spread the coils apart
about 0.5 to 1mm so that they are not touching. (The
spacing in not critical since tuning of the Tx will be done
by the trim capacitor. It is quite possible, but not as
convenient, to use a fixed value capacitor in place of the
trimcapacitor - say 47pF - and to vary the Tx frequency by
simply adjusting the spacing of the coils. That is by
varying L of the LC circuit rather than C.) Adding and
removing the batteries acts as a switch.
Connect a half or quarter wavelength antenna (length of
wire) to the aerial point. At an FM frequency of 100 MHz
these lengths are 150 cm and 75 cm respectively.
CIRCUIT DESCRIPTION
The circuit is basically a radio frequency (RF) oscillator
that operates around 100 MHz. Audio picked up and
amplified by the electret microphone is fed into the audio
amplifier stage built around the first transistor. Output
from the collector is fed into the base of the second
transistor where it modulates the resonant frequency of
the tank circuit (the 5 turn coil and the trimcap) by varying
the junction capacitance of the transistor. Junction
capacitance is a function of the potential difference
applied to the base of the transistor. The tank circuit is
connected in a Colpitts oscillator
circuit. Let us look at the individual blocks of the circuit
more closely:
The electret microphone: an electret is a permanently
charged dielectric. It is made by heating a ceramic material,
placing it in a magnetic field then allowing it to cool while
still in the magnetic field. It is the electrostatic equivalent
of a permanent magnet. In the electret microphone a slice
of this material is used as part of the dielectric of a
capacitor in which the diaphram of the microphone forms
one plate. Sound pressure moves one of its plates. The
movement of the plate changes the capacitance. The
electret capacitor is connected to an FET amplifier. These
microphones are small, have excellent sensitivity, a wide
frequency response and a very low cost.
First amplification stage: this is a standard self-biasing
common emitter amplifier. The 22nF capacitor isolates the
microphone from the base voltage of the transistor and
only allows alternating current (AC) signals to pass.
The tank (LC) circuit: every Tx needs an oscillator to
generate the radio Frequency (RF) carrier waves. The tank
(LC) circuit, the BC547 and the feedback 5pF capacitor are
the oscillator in the Cadre. An input signal is not needed
to sustain the oscillation. The feedback signal makes the
base-emitter current of the transistor vary at the resonant
frequency. This causes the emitter-collector
current to vary at the same frequency. This signal fed to
the aerial and radiated as radio waves. The 27pF coupling
capacitor on the aerial is to minimise the effect of the aerial
capacitance on the LC circuit.
The name 'tank' circuit comes from the ability of the LC
circuit to store energy for oscillations. In a pure LC circuit
(one with no resistance) energy cannot be lost. (In an AC
network only the resistive elements will dissipate electrical
energy. The purely reactive elements, the C and the L
simply store energy to be returned to the system later.)
Note that the tank circuit does not oscillate just by having
a DC potential put across it. Positive feedback must be
provided. (Look up Hartley and Colpitts oscillators in a
reference book for more details.)
CIRCUIT CALIBRATION
Place the transmitter about 10 feet from a FM radio. Set
the radio to somewhere about 89 - 90 MHz. Walk back to
the Fm Tx and turn it on. Spread the winding of the coil
apart by approximately 1mm from each other. No coil
winding should be touching another winding. Use a small
screw driver to tune the trim cap. Remove the screwdriver
from the trim screw after every adjustment so the LC
circuit is not affected by stray capicitance. Or use a plastic
screwdriver. If you have difficulty finding the transmitting
frequency then have a second person tune up and down
the FM dial after every adjustment.
One full turn of the trim cap will cover its full range of
capacitance from 6pF to 45pF. The normal FM band tunes
in over about one tenth of the full range of the tuning cap.
So it is best to adjust it in steps of 5 to 10 degrees at each
turn. So tuning takes a little patience but is not difficult.
The reason that there must be at least 10 ft. separation
between the radio and the Tx is that the Tx emits
harmonics; it does not only emit on one frequency but on
several different frequencies close to each other.
You should have little difficulty in finding the Tx
frequency when you follow this procedure.
WHAT TO DO IF IT DOES NOT WORK
Poor soldering is the most likely reason that the circuit
does not work. Check all solder joints carefully under a
good light. Next check that all components are in their
correct position on the PCB. Thirdly, follow the track with
a voltmeter to check the potential differences at various
parts of the circuit particularly across the base, collector
and emitter of the two transistors.
Are the transistors in the correct way. Is the battery flat.
Check the collector-emitter voltages (1.0 to 1.5 V). This
will tell you that the battery potential difference is across
those components.
It is possible that due to variations in tolerance the 22K
load resistor of the microphone may have to be increased
or decreased to get the best response. Reducing the value
will increase the sensitivity.
WHAT TO LEARN FROM THIS KIT
It should already be clear from the above circuit
description that there is a surprising amount of electronics
which may be learnt from this deceptively simple kit. Here
is a list of some advanced topics in electronics which can
be demonstrated or have their beginnings in this kit: Class
C amplifiers; FM transmission; VHF antennas; positive
and negative feedback; stray capacitance; crystal-locked
oscillators; signal attenuation
The simple halfwave antennae used in the kit is not the
most efficient. Greater efficiency may be gained by
connecting a dipole antennae using 50 ohm coaxial cable.
Connect one lead to the Anrenna point and the other to
the earth line.
You may experiment with using 6V or 9V with the circuit to
see how this increases the range of the transmitter. The
sensitivity may be increased by lowering the 22K resistor
to 10K. Try it and see
Note that this Tx is not suitable for use on your body, for
example, in your pocket. This is because it is affected by
external capacitance and the transmitting frequency drifts
depending how close you are to it. Stray capacitance is
automatically incorporated into the capacitance of the tank
circuit which will shift the transmitting frequency.
COMPONENTS
Resistors (carbon, 0.25W, 5%):
1M (brown, black, green 1
47K yellow, violet, orange 1
22K red, red, orange 1
10K brown, black, orange 1
470R yellow, violet, brown 1
Capacitors:
1n ceramic 102 1
5p6 ceramic 1
22n (223) ceramic 2
27p ceramic 1
100n monoblock 1
BC547, 548 2
5 turn coil 1
Electret microphone 1
Trimcap yellow (6-45pF) 1
Aerial wire 165cm
Kit PCB 1
2 AA battery holder 1
  1. مشاهدة المرفق t.zip:33:
imran imran
6 يوليو 2007
هناك ملف مرفق للدائره في حال ايجاد صعوبه في فتحه الرجاء اخباري
