بشرى لمن أراد العلم منشورات fib
الحالة
مغلق و غير مفتوح للمزيد من الردود.
hassananas
11 مايو 2006
fib Bulletins" is a generic term for a series of publications that includes several types of technical documents: Model Codes, Application Manuals, Design Guides or Recommendations, Synthesis or State-of-Art Reports, and Technical Reports, which form a detailed record of the results attained by Commissions and Task Groups in the field of research synthesis and operational application to concrete structures. Depending on a Bulletin's status, its *******s will be harmonised through approval by a Task Group (Technical Reports) or Commission (State-of-Art Reports), or, if necessary, presented, discussed and assessed by the Technical Council (Manuals, Guides and Recommendations) or the General Assembly (Model Codes). They are published irregularly, about five to six times per year.
اتمني ان تستفيدوا به
اسالكم صالح الدعاء
List of available fib Bulletins
رابط التحميل
FIB Bulletin 1: Structural concrete, volume 1 (13,2 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_54775_fib1.pdf
FIB Bulletin 2: Structural concrete, volume 2 (14,5 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_54776_fib2.pdf
FIB Bulletin 3: Structural concrete, volume 3 (15,5 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63024_fib3.pdf
FIB Bulletin 4: Lightweight aggregate concrete: codes and standards (2,5 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63025_fib4.pdf
FIB Bulletin 5: Protective systems against hazards: nature and extent of the problem (1 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_56038_fib5.pdf
FIB Bulletin 6: Special design considerations for precast prestressed hollow core floors (7 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63026_fib6.pdf
FIB Bulletin 7: Corrugated plastic ducts for internal bonded post-tensioning (820 ΚΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63027_fib7.pdf
FIB Bulletin 8: Lightweight aggregate concrete (21,3 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63028_fib8.pdf
FIB Bulletin 9: Guidance for good bridge design: part 1: introduction, part 2: design and construction aspects (21,2 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55297_fib9.pdf
FIB Bulletin 10: Bond of reinforcement in concrete (27,5 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63029_fib10.pdf
FIB Bulletin 11: Factory applied corrosion protection of prestressing steel (2,1 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63030_fib11.pdf
FIB Bulletin 12: Punching of structural concrete slabs (5,4 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_54774_fib12.pdf
FIB Bulletin 13: Nuclear containments (6 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63031_fib13.pdf
FIB Bulletin 14: Externally bonded FRP reinforcement for RC structures (3,4 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55302_fib14.pdf
FIB Bulletin 15: Durability of post-tensioning tendons (17 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63032_fib15.pdf
FIB Bulletin 16: Design examples: for the 1996 FIP recommendations “Practical design of structural concrete” (8 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55296_fib16.pdf
FIB Bulletin 17: Management, maintenance and strengthening of concrete structures (1,7 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_54773_fib17.pdf
FIB Bulletin 18: Recycling of offshore concrete structures (2 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_f4212_fib18.pdf
FIB Bulletin 19: Precast concrete in mixed construction (14,6 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55298_fib19.pdf
FIB Bulletin 20: Grouting of tendons in prestressed concrete (2,8 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55300_fib20.pdf
FIB Bulletin 21: Environmental issues in prefabrication (3,3 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55299_fib21.pdf
FIB Bulletin 22: Monitoring and safety evaluation of existing concrete structures (26,4 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63033_fib22.pdf
FIB Bulletin 23: Environmental effects of concrete (5,9 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_56037_fib23.pdf
FIB Bulletin 24: Seismic assessment and retrofit of reinforced concrete buildings (37,4 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55738_fib24.pdf
FIB Bulletin 25: Displacement – based seismic design of reinforced concrete buildings (29,2 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_55737_fib25.pdf
FIB Bulletin 26: Influence of material and processing on stress corrosion cracking of prestressing steel-case studies (5 ΜΒ)
CodeLINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63034_fib26.pdf
FIB Bulletin 27: Seismic design of precast concrete building structures (13,5 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63035_fib27.pdf
FIB Bulletin 28: Environmental design (5,1 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63036_fib28.pdf
FIB Bulletin 29: Precast concrete bridges (26,1 ΜΒ)
LINK:
http://library.tee.gr/digital/books_notee/fib_bulletin/book_63037_fib29.pdf
اسالكم صالح الدعاء
anass81
9 مارس 2007
جزاك الله خيرا على هذه الابحاث القيمة , وحبذا لو يتم تجميعها كلها في رابط واحد لتسهيل التحميل :56:
life for rent
19 يونيو 2009
جزاك الله كل خيييييييييييييييييير
21 مايو 2007
الاخ العزيز
جزاك الله كل الخير على هذه المجموعة الرائعة
يفضل ان تثبت لفترة لمحتواها القيم
و السلام عليكم
magdyamdb
3 يوليو 2009
جزاك الله كل خير و أكرمك في الدارين اللهم أمين
shuaa said
30 يونيو 2010
مواضيع جميله وجهد رائع
بارك الله بك
اياد اليوسف
20 مايو 2006
السلام عليكم اخي العزيز نشكرك على هذا الموضوع القيم ولكني اجد صعوبة في التحميل ارجوا اعادة رفعها على رابط اخر لاني جربت كل الروابط ولكن مع الاسف لم اتمكن من رفع اي ملف راجيا منك اعادة رفعها ومع جزيل الشكر
rahmeh
28 أغسطس 2006
الروابط لا تعمل
اخي العزيز اشكرك على المجهود الرائع
هل بالامكان الحصول على منشورة FIB التالية
Acceptance of stay cable systems using prestressing steels
fib Bulletin No. 30
والرجاء اعادة رفع الملفات على موقع اخر حيث ان جميع الروابط الحالية لا تعمل
وشكراً لسرعة تجاوبكم
parasismic
30 أبريل 2009
الرجاء اعادة رفع كتاب FIB Bulletin 24: Seismic assessment and retrofit of reinforced concrete buildings على المنتدى فالروابط لا تعمل ولكم جزيل الشكر .
parasismic
30 أبريل 2009
anass81
9 مارس 2007
هل بالامكان الحصول على منشورة fib التالية
acceptance of stay cable systems using prestressing steels
fib bulletin no. 30
الرجاء اعادة رفع كتاب fib bulletin 24: Seismic assessment and retrofit of reinforced concrete buildings على المنتدى فالروابط لا تعمل ولكم جزيل الشكر .
جميع الروابط لا تعمل , سوف يتم اغلاق الموضوع لحين توافر روابط جديدة
مع الشكر الجزيل للاستاذ حسان على مجهوده
الحالة
