برنامج ... Autodesk AutoCAD v2010 ... للمهندسيين
maxi33
4 فبراير 2011
Windows OS | Size: 1.28 Gb
احدث واشهر برنامج للرسم الهندسى لجميع المهندسيين
AutoCAD software lets you design, visualize, and document your ideas clearly and efficiently. From powerful 3D modeling through robust documentation nd visualization tools, AutoCAD software provides the power and flexibility to work more productively from concept through completion. If you haven’t ooked at it in a while, now is the time to check out AutoCAD 2010.
Autodesk, Inc. (NASDAQ: ADSK) is an American multinational corporation that focuses on 2D and 3D design software for use in architecture, engineering and building construction, manufacturing, and media and entertainment.
AutoCAD® software lets you design, visualize, and document your ideas clearly and efficiently. From powerful 3D modeling through robust documentation and visualization tools, AutoCAD software provides the power and flexibility to work more productively from concept through completion. If you haven’t looked at it in a while, now is the time to check out AutoCAD 2009.
Autodesk AutoCAD v2010 5000 Euro| 1.28 Gb
Release-Date …. : 2009-03-23
Supplier/Cracker ….. : Team CYGiSO
Program-Rating .. : 10/10
Price …….. : 5000 Euro
Image Format …. : ISO
ProgramType .. : CAD
Program used …. : CDRWin
Url ………. : http://www.autodesk.com
1 DVD 28×1292 MB
Requirements
Microsoft Windows XP or Vista
Intel Pentium 4 or AMD Athlon Dual Core, 1.6 GHz or higher
2 GB RAM
1 GB free hard disk space
Release-Notes
This release is an ESD (Electronic Software Distribution) version,
there is no difference between the retail dvd, only the setup is
different. Autodesk doesnt deliver .ISO Images via ESD anymore.
And all this Autodesk Releases are prestore, currently is no retail DVD available.
Install-Notes
Unrar the files
Burn or mount the Image with your favorite Tool
Start Setup and install
Follow instructions from CYGiSOreadme.txt
DownLoad
part1
part2
tanyaaladol
23 يونيو 2009
البرنامج منتهي الصلاحية مايتحمل ممكن تحديث الروابط
