اهداء لكل اعضاء المنتدى برنامج Topcon.Tools.v8.2
مصطفى المساح
28 أغسطس 2008
http://i49.tinypic.com/2ls8dvr.jpg
مواصفات البرنامج
Topcon Tools program is designed to process and adjustment of [COLOR=#0000FF !important]observations[/COLOR] by different [COLOR=#0000FF !important]surveying instruments[/COLOR].
Topcon Tools developed in such a way as to simplify the main processing operation and adjustment of field observations, which is especially important for both experienced and just starting to surveyors. The program is easy [COLOR=#0000FF !important]to install[/COLOR] on any PC, compatible with different [COLOR=#0000FF !important]operating Systems[/COLOR]of Windows.
The program has a convenient user interface that is easy to learn and use, allows you to process [COLOR=#0000FF !important]data obtained[/COLOR] from all GNSS receivers Topcon, as well as data from the receivers from other manufacturers, provided observations of [COLOR=#0000FF !important]converting files[/COLOR] to RINEX. All the data in the program are stored in the form of projects, any project settings easily changed by adding or removing the required information.
User is offered a large choice of coordinate systems, the ability to create their own and to calculate the parameters of the local coordinate system from measurements on points with known coordinates (2D and 3D calibration), and then saving them.
There is a large range of formats for [COLOR=#0000FF !important]importing and exporting[/COLOR] data. Be imported and exported to / from surveying instruments. Importing files is possible on the basis of drag & drop.
The data is loaded into the program can be displayed in the following form:
table, which contains detailed information on the points, measurements and results processing, equalization, as well as other information;
card, which includes a graphical display of measurement procedures;
sessions GNSS observations on points, which includes a graphical display of observing sessions, giving information on each of satellites;
CAD, which includes a map grid, settings and choice of substrate mapping signatures for points.
One of the distinguishing features of the program is the option to view the results of observations in Google Earth. The user only has to create the project, load observation files into it and just press one button, the program will automatically display the place in Google.
OS Microsoft Windows® XP/Vista
Processor Compatible with Intel® Pentium® 1 GHz or faster
RAM 512 MB of RAM (1 GB recommended)
Hard-disk Space 300 MB of available hard-disk space
Graphics 17” or larger monitor recommended, displaying 256 colors
Language englich include russian
التحميل من الرابط الاسفل
Topcon.Tools.v8.2.rar | FilesIn.com
24 أكتوبر 2007
دائما سباق بالخير انا كنت ببحث اليوه علي هذا البرنامج . جزاك الله و جعله في موازين حسناتك ان شاء الله يوم القيامة
كنت اريد بعد اذنك برنامج kml لبرنامج gis
akhilali
25 ديسمبر 2009
شكراً جزيلاً أخي وفقك الله لما يحب ويرضى ...
تحياتي : المهندس العراقي
مصطفى المساح
28 أغسطس 2008
ملحوظه الكراك يعمل على ويندوز 32 بيت لم يعمل معى فى ويندوز 64 بيت
xbatma
7 أكتوبر 2009
السلام عليكم اخي الكريم ممكن ان تعيد رفع الملف من جديد ان الربط غير شغال و شكرا جزيــــــــــــــــل الشكر
