اليرنامج الرائع فى حفظ وتشفير وإخفاء الملفات الشهيرFolder Lock 7.2.0 بأحدث إصدار
medo2013
16 يناير 2013
أقدم لكم Folder Lock v7.2.0 Final
= - = - = - = - = - = - = - = - = - = - = - = - = INFO = - = - = - = - = - = - = - = - = - = - = - = - =
البرنامج الرائعFolder Lock 7.2.0 Final يقوم البرنامج بحفظ الملفات في خزانة خاصة ينشؤهاوبعد اغلاق البرنامج تختفي هذه الخزانه. برنامج يمتاز بالشعبية الكبيرة لانه أكثر برامج تشفير الملفات امانا البرنامج يحمى ويقفل الملفات والمجلدات والدرايفات بكلمة سر ويخفي ويشفر الصور والوثائق بلحظة واحدة كما انك تستطيع حماية الملفات الموجودة في usb flash drives, memory sticks,cd-rw, floppies and notebooks
Folder Lock is fast file-security software that can password-protect, lock, hide, and encrypt any number of files, folders, drives, pictures, and ********s in seconds. Locked files are undeletable, unrenamable, unmovable, hidden, and inaccessible. You can lock, scramble, or encrypt depending on speed and security. Folder Lock is fully portable, so you can protect your files on USB flash drives, disks, CD-RWs, notebooks, and hard disks, and it doesn't require installation on another PC. Folder Lock protects files in Windows, DOS, and Safe modes, even when you change your OS or boot from a disk. Folder Lock doesn't let you delete its own program folder, and it can't be uninstalled without the correct password. Additional options include Stealth Mode, Hacker Attempt Monitoring, Shred files, AutoLock, Auto Shutdown PC, Lock your PC, Erase PC tracks, 256-bit Blowfish Encryption and Context Menu in Explorer. Encrypt Files Encrypt your personal files using 256-bit on-the-fly encryption technology totally dynamic and fool-proof. Protect USB / CD Convert your encrypted storages into executables and take your portable drives anywhere. Make Wallets Store sensitive information in encrypted form. A safe haven for private info like Credit Cards and Bank Accounts. Run Application in complete Stealth. Don't let anyone know you ever installed Folder Lock on your PC. Password Security Restrict access to various parts of the application with use of admin level master password. Auto Protection Set inactivity based security policy in order to secure everything when you're away from your PC. Hack Security Don't let hackers use dictionary attacks. Monitor, control and perform actions on incorrect password attempts. Shred Files Shred and permanently delete restorable files, folders and drives and even empty hard drive space. Lock Files Protect important files from unwanted access by blocking visibility or access to files, folders and drives. Backup Online Backup all your encrypted files automatically to an online storage and easily restore it back.
robocon
8 يونيو 2009
جزاك الله خيرا
أخي الحبيب
