الرائع لاضافة التأثيرات على الصور AMS Software Photo Effects 2.97
adana
25 مايو 2010
تم تصغير هذه الصورة. اضغط هنا لمشاهدة الحجم الكامل. أبعاد الصورة الاصلي هو 750*300.
برنامج يتيح لك اضافة الكثير من التأثيرات على الصور
ويوفر الكثير من الاطارات وياعدك على بطاقات التهنيئه والكثير ..
Photo Effects is a program that will allow you to process your photos by using various filters. With it, you can completely transform any image.Photo Effects allows you to use more than 50 effects, including both traditional and original ones. You will be able to take a look at your photos in the rain and snow, in fog and up in the sky, add some sun light to it or swirl it in a typhoon...You can combine effects and create truly fantastic compositions. It is possible to apply the selected filters both to the entire image and to its parts highlighting the most important fragment of the photo.Photo Effects will help to decorate your home photo album, website and will even allow you to create an original greeting card.
Photo Effects makes it possible to not only process, but also decorate photos. It offers you more than 100 frames and masks that will decorate portraits, landscapes and even simple casual shots.It is important that you can apply effects both before and after you decorate a photo. Combining effects and frames is one of the main features of the program. For example, you can apply a classic frame and then use lighting effects to add realistic sunlight to its contour. Try to use this feature more often and you will see how pretty the images Photo Effects creates are.
Key Features:
· Effects. There are five categories of filters here: color effects, lighting effect, traditional, artistic and distortion filters.
· Decoration. If you open this tab, you will find five types of frames, including classic frames, relief frames, masks, etc.
· Composition. This feature allows you to position your photo on the page in a beautiful way
16.02MB
http://www.mediafire.com/?7dkwuim0tirq2hd
