التحكم بالشروخ Crack Control
امين الزريقي
22 سبتمبر 2008
الكتيب المرفق يشرح طريقة حساب عرض الشروخ في العناصر الخرسانية اضافة الى وسائل التحكم بها سواء كانت ناتجة عن التغيرات الحرارية او نتيجة للتحميل وما ينتج عنه من اجهادات شادة او سواها مما يمكن ان يؤدي الى تطور في حركة الشروخز الكتاب بريطاني المصدر لذلك فاعتماده الاساس على الكودات و المنشورات الصادرة عن الهيئات البريطانية ويعكس الممارسات المهنية البريطانية.
  • Crack control.pdf
    2.8 MB · المشاهدات: 65
امين الزريقي
22 سبتمبر 2008
متابعة للموضوع
Early-Age Cracking
A summary of the latest document from ACI Committee 231
ACI Committee 231, Properties of Concrete at Early
Ages, defines “early age” as the period after final
setting, during which properties change rapidly. For a
typical Type I Portland cement concrete moist-cured at
room temperature, this period is about 7 days, but it can
extend beyond 7 days for other mixtures and curing
conditions. Early-age volume changes induced by temperature
change, hydration, and drying shrinkage can
lead to cracking, and this can have lasting effects on
.strength, serviceability, and durability.
As is indicated in the title “Report on Early-Age Cracking
Causes, Measurement, and Mitigation (ACI 231R-10),” the
latest report from ACI Committee 231 discusses the
measurement and mitigation of early-age cracking.1 The
following is a summary of the report. References are
provided only for the report itself and the figures used in
the summary. The committee report contains numerous
.additional references
Causes of Early-Age Cracking
Early-age cracking arises from restraint of volume
changes associated with thermal deformation, shrinkage
.due to hydration reactions, and shrinkage due to drying
Thermal deformation
A hypothetical example of the effects of thermal
deformation is provided in Fig. 1, which shows air and
concrete temperature, stress, and tensile strength as
.functions of time
Upon final setting (Time A), concrete begins to develop
resistance to compressive and tensile strains. After Time A
the combined effects of hydration and, in this example,
increasing air temperature cause the concrete temperature
to increase until it reaches a peak (Time B). From Time A
to Time B, the increasing concrete temperature causes
thermal expansion. Restraint of this expansion by
adjacent concrete or structures generates increasing
.compressive stress in the concrete​
تقرير عن شروخ الخرسانة التي تحدث في عمرها المبكر نتيجة تقييد حركتها.
  • Early Age Cracking Report on .pdf
    147.7 KB · المشاهدات: 14
امين الزريقي
22 سبتمبر 2008
ملخص لأحدث وثيقة من لجنة ACI 231 ACI Committee 231 ، خصائص الخرسانة في عمرها المبكر ، يعرف "العمر المبكر" على أنه الفترة التي تلي عملية الشك النهائي ، والتي خلالها تتغير الخصائص بسرعة. بالنسبة لخرسانة الأسمنت البورتلاندي العادي المعالجة بالترطيب من النوع الأول في درجة حرارة الغرفة ، تستغرق هذه الفترة حوالي 7 أيام ، ولكن يمكن أن تمتد لأكثر من 7 أيام للخلطات الأخرى وتبعاً لظروف المعالجة. يمكن أن يحدث التشقق بسبب التغييرات الحجمية للخرسانة في عمرها المبكر نتيجة للتغير في درجة الحرارة ، والتميه hydration ، وانكماش التصلب ، ويمكن أن يكون لهذا تأثيرات دائمة على القوة ، وقابلية الاستخدام ، إضافة الى الديمومة, كما هو موضح في العنوان "تقرير عن تتشقق الخرسانة في العمر المبكر : الاسباب والقياس ، والتخفيف من الآثار الناتجة عن ذلك (ACI 231R-10) ، وفيما يلي ملخص للتقريرالصادر عن لجنة ACI 231 الذي يبحث قياس وتقليل أضرار التشقق المبكر. تم ذكر مراجع التقريروكذلك الحسابات المستخدمة في الخلاصة . كما يحتوي التقرير على العديد من المراجع الاخرى.
