استفسار من الساده المهندسين الافاضل
mohamed diad
23 فبراير 2013
كان عندى سؤال شاغل بالى و هو الفرق بين المنشاءات الخطيه و اللاخطيه
و المنشاءات المطيله و الغير مطيله
linear and nonlinear systems
elastic and inelastic systems
abdoo_farra
11 يوليو 2006
A linear analysis is undertaken when a structure is expected to behave linearly, i.e. obeys Hook’s Law. The stress is proportional to the strain, and the structure will return to its original configuration once the load has been removed. A structure is a load bearing member and can normally be classified as a bar, beam or column
Conversely, a non-linear is used to predict the behavior of a structure that is loaded beyond the elastic limits of the material of interest. The structure experiences plastic deformation and will not return to its original configuration or shape​
