ارجو المساعدة و في كيفية تقويتي في مجال التعامل مع ال signal
محمد جعبري
5 يوليو 2010
انا طالب هندسة اتصالات و عندي ضعف باشي اسمه signal ...كيف ممكن اقوي حالي بهذا المجال و للعلم هذا صلب تخصصي.
تحياتي للجميع
ramij
5 ديسمبر 2010
Electrical Signla
You have to upgrade your knowledge in this field specially the electrical signal because all the communication depend on it
Electrical signal : is a voltage or current which conveys information, usually it means a voltage. The term can be used for any voltage or current in a circuit
:properties of electrical signals
Amplitude is the maximum voltage reached by the signalIt is measured in volts, V
Peak voltage is another name for amplitude
Peak-peak voltage is twice the peak voltage (amplitude). When reading an oscilloscope trace it is usual to measure peak-peak voltage
Time period is the time taken for the signal to complete one cycle
It is measured in seconds (s), but time periods tend to be short so milliseconds (ms) and microseconds
µs) are often used. 1ms = 0.001s and 1µs = 0.000001s
Frequency is the number of cycles per second
It is measured in hertz (Hz), but frequencies tend to be high so kilohertz (kHz) and megahertz (MHz) are often used. 1kHz = 1000Hz and 1MHz = 1000000Hz
I hope that i helped you
best regards
good luck​
محمد جعبري
5 يوليو 2010
شكرا رامي
انا بدي معلومات عن كيف ال signal بتحمل معلومات و بتنقلها؟؟
ramij
5 ديسمبر 2010
ابعتلي المادة النظرية وانا بفهمك كل شيء فيها
اسف على انشغالي و عدم الرد
