ارجو الرد فى اسرع وقت
the spirt
2 مارس 2010
انا عاوز اعرف ازاى اقرأ قيم الملفات يعنى من الاخر بأستخدام ال data sheet زى المقاومات كده بقرأها من الالوان من غير ما اقيس عاوز اعرف بقى الملفات اقرأها ازاى انا لسه طالب فى اولى اتصالات يعنى علشان متستغربوش من السؤال وشكرا ليكم مقدما
Mohammed El-Gaily
26 مارس 2010
السلام عليكم .. العفو ياهندسة مافي أي أستغراب ولاخجل من العلم ربنا أقدمك ويوفقك أمين...
أنصحك بقراءة الملفات دي بي صبر وسعة أفق ودراسة ونحن تحت أمرك...
Testing coil is very easy compares to checking three leads components such as SCR, FET and etc. In general, a coil consists of many turns or wire wrapped around a common core. The core could be made of iron or even air
When an electric current passes through the coil, a magnetic field is produced. A coil in some respect s acts just opposite a capacitor. A capacitor blocks DC while allowing AC to flow through it; a coil allows DC to flow through it while restricting AC current flow. Another name for a coil is an inductor
Coil or inductor can be test using an analog, inductance or a coil meter such as the dick smith flyback tester. A coil that is small in size, I would usually just test it with analog meter and you could check it on board too. Set your analog meter to X1 ohm and place the probes across the small coil. The meter should show some reading (or continuity) and this proved that the coil winding is okay. Small coils seldom spoilt because it have less winding compares to big coils where it could have many turns of winding and chances for it to go shorted is very high.
Testing bigger coil or inductor such as the computer monitor B+ coil, you need an inductance meter to find out the exact inductance value which is in the unit of henry (h). From experienced using an inductance meter to check coils to see if it good or bad is not recommended because a shorted coil (shorted between winding) could have a good inductance value and you would miss out checking a bad coil. Unless you want to use the inductance meter to calculate the reading and do rewinding, looping and etc on that coil. I would only test a big coil with dick smith flyback meter. Any shorted winding in it could be easily detected by this meter.
Now is the time to share my true case example- a computer dealer send me a monitor for repair with power blink symptom. Usually I do not straight away repair the monitor but I would first use the flyback tester to scan all the major coils (smps, flyback, b+ coil and horizontal deflection coil) before using my digital or analog meter to do testing.
When measuring the B+ coil, the Led lights went off and it suppose to show at least 5 LED bars and above. Upon soldering out the coil, I did not see any burn mark at the winding or loop and in fact it looks shiny. Because I trust the meter, I opened up the winding and to my surprised the internal winding had burnt into crisp but the outer winding looks good indeed! A new B+ coil restored the monitor to life.
By using a flyback tester for testing coil, it has helped me to locate many shorted coils in switch mode power transformer primary winding, B+ coil, flyback transformer primary winding and horizontal deflection coil. The flyback meter can even be used to check the condition of ballast in fluorescent lamp too!
يمكنك مراجعتي أذا أحتجت الترجمة.. مع عدم النصح بها..
ماجد عباس محمد
3 سبتمبر 2006
عادة الملفات إما يكتب عليها أو تكون بنفس الأوان مثل المقاومات لكن للأسف كثير منها لا يكتب عليه قيمته لذا يجب القياس
